Triode Spotify Plugin
Tom7320
Beitrag von Tom7320 »
Hallo!
Da ich stolzer Besitzer einer SB Boom bin, habe ich mein Glück mit dem Triode Spotify Plugin probiert. Zuerst hatte ich zusätzlich das offizielle Spotify Plugin installiert. Nachdem das nicht geklappt hat, habe ich das offizielle Plugin deinstalliert. Wenn ich den Selbsttest des Triode Plugins ausführe, stoppt dieses mit "Unable to authenticate player" und "Helper app unable to authenticate player (error: -1)". Im Log steht IMHO nichts zielführendes:
[19:54:06.067135] main:727 newstream connection from 192.168.0.30
[19:54:06.067154] main:763 streamid: 0 newid: 17 type: FLAC
[19:54:06.070377] check_player:198 cli connection error: Connection reset by peer 104
[19:54:06.070445] main:785 unable to play on this player: -1
[19:54:10.679562] main:493 new connection
[19:54:10.680608] main:539 req: cover.jpg res: spotify:image:f0dd4a841252c146768d8a6637a45a270ab913af par: (null) prot: HTTP/1.0 auth: (null)
[19:54:11.351033] write_cover:33 cover fetch: No error
[19:54:11.681855] main:493 new connection
[19:54:11.682969] main:539 req: cover.jpg res: spotify:image:f0dd4a841252c146768d8a6637a45a270ab913af par: (null) prot: HTTP/1.0 auth: (null)
[19:54:11.683792] write_cover:33 cover fetch: No error
[19:54:36.003285] main:493 new connection
[19:54:36.004380] main:539 req: prefetch.json res: spotify:track:3OhFnVdXqYSM2GunYD3Oa9 par: (null) prot: HTTP/1.0 auth: (null)
[19:54:36.004625] main:903 prefetching track: No error
[19:54:38.400913] log_message:80 log: 17:54:38.400 I [file_streamer_simple.cpp:789] Request for file 38f116c4e28a3107d51b5ba2de54471051b6036d complete (code: 0)
[19:55:45.394019] main:493 new connection
[19:55:45.394107] main:539 req: stream.flc res: spotify:track:3OhFnVdXqYSM2GunYD3Oa9 par: player=00%3A04%3A20%3A1e%3Ae2%3A04&start=0&sync=1&id=18 prot: SPOTSTREAM/1.0 auth: (null)
[19:55:45.394166] main:727 newstream connection from 192.168.0.30
[19:55:45.394182] main:763 streamid: 0 newid: 18 type: FLAC
[19:55:45.395223] check_player:198 cli connection error: Connection reset by peer 104
[19:55:45.395286] main:785 unable to play on this player: -1
[19:58:05.054110] end_of_track:619 end of track
[19:58:58.110985] main:493 new connection
[19:58:58.111744] main:539 req: status.json res: (null) par: (null) prot: HTTP/1.0 auth: (null)
[19:58:58.111838] process_status:1286 process status
[19:59:03.468418] main:493 new connection
[19:59:03.469165] main:539 req: status.json res: (null) par: (null) prot: HTTP/1.0 auth: (null)
[19:59:03.469259] process_status:1286 process status
[19:59:07.569868] main:493 new connection
[19:59:07.570597] main:539 req: status.json res: (null) par: (null) prot: HTTP/1.0 auth: (null)
[19:59:07.570691] process_status:1286 process status
[20:01:16.002460] main:493 new connection
[20:01:16.003542] main:539 req: prefetch.json res: spotify:track:3OhFnVdXqYSM2GunYD3Oa9 par: (null) prot: HTTP/1.0 auth: (null)
[20:01:16.003699] main:903 prefetching track: No error
[20:11:16.617947] logged_out:60 logged out
[21:18:11.957415] main:493 new connection
[21:18:11.958276] main:539 req: status.json res: (null) par: (null) prot: HTTP/1.1 auth: (null)
[21:18:11.958371] process_status:1286 process status
[21:18:11.972875] main:493 new connection
[21:18:11.973752] main:539 req: toplist.json res: (null) par: q=tracks&r=user prot: HTTP/1.1 auth: (null)
[21:18:11.975174] main:618 relogging in as user: 1128904876
[21:18:11.977903] log_message:80 log: 19:18:11.977 I [ap:1766] Connecting to AP ap.spotify.com:4070
[21:18:11.979578] logged_in:53 logged in
[21:18:12.063282] log_message:80 log: 19:18:12.063 I [ap:1224] Connected to AP: 78.31.12.94:4070
[21:18:12.979850] main:1130 toplist type: 2 region: 17477
[21:18:13.004462] toplist_callback:715 toplist: ok
[21:18:13.011940] metadata_updated:85 new meta
[21:18:13.025233] main:493 new connection
[21:18:13.026206] main:539 req: status.json res: (null) par: (null) prot: HTTP/1.1 auth: (null)
[21:18:13.026276] process_status:1286 process status
[21:18:13.037689] main:493 new connection
[21:18:13.038080] main:539 req: streamtest.json res: (null) par: (null) prot: HTTP/1.1 auth: (null)
[21:18:13.038170] main:878 streambuf_newstream: streamtest (1)
[21:18:13.038182] main:879 created teststream radio search to find track
[21:18:13.088996] metadata_updated:85 new meta
[21:18:13.152719] teststream_search_callback:884 found track
[21:18:13.153095] metadata_updated:85 new meta
[21:18:13.153142] main:1791 streambuf_newstream: test
[21:18:13.182443] main:1575 Now playing: Born This Way
[21:18:13.183040] metadata_updated:85 new meta
[21:18:13.397788] music_delivery:480 channels: 2 sample rate: 44100 streaming as: PCM
[21:18:13.901898] log_message:80 log: 19:18:13.901 I [file_streamer_simple.cpp:789] Request for file 1607854994fda4660d78723d64fcf4f741a91598 complete (code: 0)
[21:18:14.220268] log_message:80 log: 19:18:14.220 I [file_streamer_simple.cpp:789] Request for file 1607854994fda4660d78723d64fcf4f741a91598 complete (code: 0)
[21:18:31.377531] log_message:80 log: 19:18:31.377 I [file_streamer_simple.cpp:789] Request for file 1607854994fda4660d78723d64fcf4f741a91598 complete (code: 0)
[21:18:50.544124] log_message:80 log: 19:18:50.544 I [file_streamer_simple.cpp:789] Request for file 1607854994fda4660d78723d64fcf4f741a91598 complete (code: 0)
[21:19:10.136824] log_message:80 log: 19:19:10.136 I [file_streamer_simple.cpp:789] Request for file 1607854994fda4660d78723d64fcf4f741a91598 complete (code: 0)
[21:19:30.146316] log_message:80 log: 19:19:30.146 I [file_streamer_simple.cpp:789] Request for file 1607854994fda4660d78723d64fcf4f741a91598 complete (code: 0)
[21:19:49.541135] log_message:80 log: 19:19:49.541 I [file_streamer_simple.cpp:789] Request for file 1607854994fda4660d78723d64fcf4f741a91598 complete (code: 0)
[21:20:08.701404] log_message:80 log: 19:20:08.701 I [file_streamer_simple.cpp:789] Request for file 1607854994fda4660d78723d64fcf4f741a91598 complete (code: 0)
[21:21:04.450313] end_of_track:619 end of track
[21:21:04.468547] main:493 new connection
[21:21:04.469686] main:539 req: streamtest.json res: spotify:track:30XU4suKzCeoCK9YFzdufg par: (null) prot: HTTP/1.1 auth: (null)
[21:21:04.469883] main:844 streambuf_newstream: streamtest (2)
[21:21:04.469983] main:1575 Now playing: Born This Way
[21:21:04.495579] main:493 new connection
[21:21:04.507677] main:539 req: browse.json res: spotify:track:30XU4suKzCeoCK9YFzdufg par: (null) prot: HTTP/1.0 auth: (null)
[21:21:04.507779] main:996 queuing track browse
[21:21:04.507797] process_track:1204 process track
[21:21:04.507833] process_track:1230 browse track: ok
[21:21:04.508144] main:493 new connection
[21:21:04.508685] main:539 req: browse.json res: spotify:track:30XU4suKzCeoCK9YFzdufg par: (null) prot: HTTP/1.0 auth: (null)
[21:21:04.508729] main:996 queuing track browse
[21:21:04.508743] process_track:1204 process track
[21:21:04.508772] process_track:1230 browse track: ok
[21:21:04.643954] main:493 new connection
[21:21:04.645071] main:539 req: stream.flc res: spotify:track:30XU4suKzCeoCK9YFzdufg par: player=00%3A04%3A20%3A1e%3Ae2%3A04&start=0&sync=1&id=19 prot: SPOTSTREAM/1.0 auth: (null)
[21:21:04.645222] main:727 newstream connection from 192.168.0.30
[21:21:04.645247] main:763 streamid: 0 newid: 19 type: FLAC
[21:21:04.646293] check_player:198 cli connection error: Connection reset by peer 104
[21:21:04.646380] main:785 unable to play on this player: -1
[21:21:08.056091] main:493 new connection
[21:21:08.057132] main:539 req: cover.jpg res: spotify:image:5eea55bdb892b98aa07216f97bf6d44a661b58de par: (null) prot: HTTP/1.0 auth: (null)
[21:21:08.141893] write_cover:33 cover fetch: No error
[21:21:09.061794] main:493 new connection
[21:21:09.062932] main:539 req: cover.jpg res: spotify:image:5eea55bdb892b98aa07216f97bf6d44a661b58de par: (null) prot: HTTP/1.0 auth: (null)
[21:21:09.064961] write_cover:33 cover fetch: No error
[21:21:34.002852] main:493 new connection
[21:21:34.003940] main:539 req: prefetch.json res: spotify:track:30XU4suKzCeoCK9YFzdufg par: (null) prot: HTTP/1.0 auth: (null)
[21:21:34.004198] main:903 prefetching track: No error
[21:23:55.751945] end_of_track:619 end of track
Woran liegt das? Wie kann ich es reparieren? Zur Hardware:
Logitech Media Server Version: 7.7.2 - r33893 @ Wed Mar 14 05:46:46 PDT 2012
Hostname: micro
IP: 192.168.0.10
HTTP-Port: 9000
BS: Debian - DE - utf8
Plattform: x86_64-linux
Perl-Version: 5.14.2 - x86_64-linux-gnu-thread-multi
Anzahl erkannter Player: 2
Player-Modell: Squeezebox Boom
Firmware: 57
IP-Adresse des Players: 192.168.0.30
MAC-Adresse des Players: 00:04:20:1e:e2:04
Stärke des drahtlosen Signals: 87%
Player-Modell: Squeezebox Radio
Firmware: 7.7.2-r9663
IP-Adresse des Players: 192.168.0.31
MAC-Adresse des Players: 00:04:20:2a:f9:a1
Stärke des drahtlosen Signals: 100%
Für etwas Hilfe wäre ich sehr dankbar!
Beste Grüße,
Thorsten
Re: Triode Spotify Plugin
seltsam das so lange keine Antwort gekommen ist. Ich selber habe mich erst gestern bei Spotify registriert und hatte dieselbe Meldung
War dann auch etwas planlos und habe auf das Spotify-Icon (orange) im Hauptmenü geklickt, in Unkenntnis das dies das offizielle Plugin ist, und eine Fehlermeldung auf dem Display der Touch erhalten wenn ich einen Titel abspielen wollte
Hab dann auf der Logitech-Webseite unter "meine Anwendungen" meine Zugangsdaten eingegeben und die gewünschten Squeezen aktiviert, dann lief es
Heute hatte ich dann (plötzlich?) ein 2tes Spotify-Icon (grün) im Menü, und auch das funktioniert problemlos. beide Plugins laufen problemlos nebeneinander
Welches ich besser finde weiß ich noch nicht. Beim Offiziellen finde ich die Punkte "zuletzt gehörte Interpreten" und Alben sehr interessant, die fehlen mir beim Triode
Außerdem finde ich das etwas unübersichtlich da es auch die iTunes-Playlisten in der ersten Menüebene anzeigt. Da wäre ein weiteres Untermenü nicht schlecht.
Wer iTunes auf dem PC etc nutzt mag das gut finden, bei mir dienen sie eigentlich nur dazu die Apple-Geräte meiner Frau und meines Sohnes zu synchronisieren. Deswegen stören sie mich eigentlich nur
Du irrst.
Das orangene Icon ist von Triode, das grüne ist von Logitech.
ach du Schande :)
Dann werde ich das offizielle wohl runter schmeißen
Synchronisieren wird mir früher odr später wohl wichtig sein. Spätestens auf der nächsten Party :)
Lass es drauf. Die beiden arbeiten zusammen.
Synchronisation geht doch mit beiden.
merk ich auch gerade das es ohne nicht ght ;)
Ich hatte irgendwo im Hinterkopf nur Triode könne sncen
meine Boom spielt kein Spotify ab
Wenn ich auf eine Playliste zugreife erscheint der erste Titel und "Verbindung wird hergestellt" für ein paar Sekunden
Dann springt sie weiter zum nächsten Titel (ohne einen Ton von sich zu geben) und so weiter
Habs über Eigene Anwendungen-->Spotify versucht und auch über unter "Eigene Musik" erstellte Wiedergabelisten
Versuche ich die Boom mit der Touch zu syncen verhält diese sich dann ebenso
Evtl musst Du in den Einstellungen des Triode-Plugins einstellen, dass immer darüber abgespielt werden soll.
Ich habe das auch manchmal, geht aber immer wieder weg, frag mich aber bitte nicht, wie
Hi coolio
meinst du den Haken bei "Helfer Anwendung"?
Stream-Qualität auf "Hoch" (320k) sollte keine Probleme machen?
