Unterbrechungen am Server
gerkoe60
SqueezeBox Server läuft auf: Windows 7
Beitrag von gerkoe60 »
Alle paar Minuten gibt es kurze Aussetzer. Im Log des Servers wird dann jeweils eine Zeile protokolliert:
[10-07-10 11:18:59.9560] Slim::Utils::Misc::msg (1165) Warning: [11:18:59.9558] Use of uninitialized value in division (/) at /<D:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Player/StreamingController.pm line 867.
[10-07-10 11:23:48.6100] Slim::Utils::Misc::msg (1165) Warning: [11:23:48.6097] Use of uninitialized value in division (/) at /<D:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Player/StreamingController.pm line 867.
[10-07-10 11:28:24.5720] Slim::Utils::Misc::msg (1165) Warning: [11:28:24.5718] Use of uninitialized value in division (/) at /<D:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Player/StreamingController.pm line 867.
[10-07-10 11:33:24.4550] Slim::Utils::Misc::msg (1165) Warning: [11:33:24.4548] Use of uninitialized value in division (/) at /<D:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Player/StreamingController.pm line 867.
[10-07-10 11:38:33.7845] Slim::Utils::Misc::msg (1165) Warning: [11:38:33.7842] Use of uninitialized value in division (/) at /<D:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Player/StreamingController.pm line 867.
[10-07-10 11:42:57.8473] Slim::Utils::Misc::msg (1165) Warning: [11:42:57.8471] Use of uninitialized value in division (/) at /<D:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Player/StreamingController.pm line 867.
[10-07-10 11:49:53.6740] Slim::Utils::Misc::msg (1165) Warning: [11:49:53.6738] Use of uninitialized value in division (/) at /<D:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Player/StreamingController.pm line 867.
[10-07-10 11:54:15.5356] Slim::Utils::Misc::msg (1165) Warning: [11:54:15.5354] Use of uninitialized value in division (/) at /<D:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Player/StreamingController.pm line 867.
[10-07-10 11:57:35.7870] Slim::Utils::Misc::msg (1165) Warning: [11:57:35.7867] Use of uninitialized value in division (/) at /<D:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Player/StreamingController.pm line 867.
[10-07-10 12:01:38.2937] Slim::Utils::Misc::msg (1165) Warning: [12:01:38.2935] Use of uninitialized value in division (/) at /<D:\PROGRA~2\SQUEEZ~1\server\SQUEEZ~3.EXE>Slim/Player/StreamingController.pm line 867.
Administrator
Re: Unterbrechungen am Server
Beitrag von Kevin »
Welche Server Version?
Lässt du den Server auf dem PC laufen? Wie viele SqueezeBoxen hast du?
Du könntest auch den internen Server auf der Touch benutzen und ne externe Platte dran hängen, denn muss nicht jedes mal den Rechner laufen lassen.
gerkoe60
Eine Squeezebox! Der Server läuft auf einem Notebook, auf dem sich auch meine Musiksammlung befindet. Soll auch dort bleiben!
Administrator
Beitrag von Kevin »
Bleibt noch die Frage: welche Serverversion?
Tritt das Problem beim abspielen von mp3 oder von Radiostreams auf? Tritt es auch bei anderen / allen Alben, bzw Streams auf?
tjareson
SqueezeBox Server läuft auf: QNAP Linux NAS
Beitrag von tjareson »
weiss eigentlich irgendjemand mehr zu diesem Thema?
Bei mir läuft die Version 7.5.1 auf einem QNAP NAS (also Linux) und ich habe das gleiche Phänomen, wenn auch sehr viel seltener. Aber wenn es auftritt, dann in der Regel mehrere Male hintereinander.
Der Server zeigt währenddessen an, dass er ganz normal weiterstreamt. Auch die Squeezebox ist per http erreichbar, nur hört man nichts.
Die Meldung im Log ist die gleiche...
Grüße.
Tjareson
