lms scan funktioniert nicht mit dem neuestem release
pixelbit
SqueezeBox Server läuft auf: linux
Beitrag von pixelbit »
hallo zusammen,
mein lms laeuft auf linux (sles 11 sp 3 ).
leider funktioniert das neu scannen mit dem release: logitechmediaserver-7.9.0-0.1.1421845197.noarch.rpm nicht.
wohl aber mit dem vorheringen release: logitechmediaserver-7.8.1-0.1.1418369688.noarch.rpm
hier die logeintraege:
scann.log:
[15-01-23 14:36:30.1752] main::main (203) Starting Logitech Media Server scanner (v7.9.0, 1421845197, Thu Jan 22 04:01:01 UTC 2015) perl 5.010000
[15-01-23 14:36:30.3668] Slim::Schema::forceCommit (2149) Warning: Trying to commit transactions before DB is initialized!
[15-01-23 14:36:30.6850] Slim::Music::Import::runImporter (485) Starting Slim::Media::MediaFolderScan scan
[15-01-23 14:36:30.6856] Slim::Utils::Scanner::Local::rescan (177) Discovering audio files in /srv/media/music
[15-01-23 14:36:53.4249] Slim::Utils::Scanner::Local::__ANON__ (188) Start processing found tracks
[15-01-23 14:36:53.4252] Slim::Utils::Scanner::Local::__ANON__ (196) Connect do DB
[15-01-23 14:36:53.4253] Slim::Utils::Scanner::Local::__ANON__ (199) Get latest ID
[15-01-23 14:36:53.4255] Slim::Utils::Scanner::Local::__ANON__ (221) Delete temporary table if exists
[15-01-23 14:36:53.4257] Slim::Utils::Scanner::Local::__ANON__ (224) Re-build temporary table
[15-01-23 14:36:53.6855] Slim::Utils::Scanner::Local::__ANON__ (259) Get deleted tracks count
[15-01-23 14:36:53.6859] Slim::Utils::Scanner::Local::__ANON__ (266) Get new tracks count
[15-01-23 14:36:53.6878] Slim::Utils::Scanner::Local::__ANON__ (271) Get changed tracks count
[15-01-23 14:36:53.7706] Slim::Utils::Scanner::Local::__ANON__ (277) Removing deleted audio files (0)
[15-01-23 14:36:53.7708] Slim::Utils::Scanner::Local::__ANON__ (355) Scanning new audio files (69476)
[15-01-23 14:36:53.7796] main::main (325) Warning: Assertion he->shared_he_he.hent_hek == hek failed: file "hv.c", line 2243 at /usr/libexec/squeezeboxserver-scanner line 325.
[15-01-23 14:36:53.7798] main:: (325) Warning: panic: bad free at /usr/libexec/squeezeboxserver-scanner line 325.
[15-01-23 14:36:53.7800] main:: (325) Warning: Assertion he->shared_he_he.hent_hek == hek failed: file "hv.c", line 2243 at /usr/libexec/squeezeboxserver-scanner line 325.
server.log(auszug):
fined value at /var/lib/squeezeboxserver/cache/InstalledPlugins/Plugins/SuperDateTime/lib/Plugins/SuperDateTime/Plugin.pm line 3241.
; fh=Slim::Networking::Async::Socket::HTTP=GLOB(0x95dfca8)
[15-01-23 14:36:53.8267] Slim::Utils::SQLiteHelper::postConnect (371) Optimizing DB because of missing or empty sqlite_stat1 table
[15-01-23 14:36:53.9978] Slim::Schema::forceCommit (2149) Warning: Trying to commit transactions before DB is initialized!
scheint wohl was mit der db nicht zu stimmen.
hat jemand eine idee wie ich das problem loesen kann?
danke!
gruesse
Re: lms scan funktioniert nicht mit dem neuesetn release
Ist das der heutige Build? Da musst Du auf jeden Fall ein "Clear&Rescan", die Datenbankstruktur hat sich geändert. Sollte der Server von alleine machen, vielleicht hat er das bei Dir nicht erkannt.
pixelbit
coolio hat geschrieben:Ist das der heutige Build? Da musst Du auf jeden Fall ein "Clear&Rescan", die Datenbankstruktur hat sich geändert. Sollte der Server von alleine machen, vielleicht hat er das bei Dir nicht erkannt.
ja habe ich gemacht! keiner der scan vorgaenge funktioniert.
pixelbit
habe soeben das neueste release installiert: logitechmediaserver-7.9.0-0.1.1421917265.noarch.rpm
das einscannen klappt auch bei dieser version nicht :(
in der version 7.8 funktionierte es aber :)
Kannst Du das mal im Slimdevices Forum posten?
HTTP://forums.slimdevices.com
noname
SqueezeBox Server läuft auf: Intel NUC i3
Beitrag von noname »
Hab das jetzt mal auf x86_64 getestet und kann das NICHT bestätigen!
Meine Hardware:
2x Transporter
4x Touch
5x Radio
1x Receiver
2x Controller
pixelbit
noname hat geschrieben:Hab das jetzt mal auf x86_64 getestet und kann das NICHT bestätigen!
mein lms 7.9 laeuft auf x86_64, software wird wie oben beschrieben per rpm paket installiert.
wie gesagt die 7.8 version laeuft auch ohne probleme, nur die neu 7.9 nicht:(
